wont start
Old Sep 19, 2004 | 08:40 PM
kamaroirock's Avatar
Car: 02 z28, 03 wrangler sport
Engine: ls1, 4.0L
Transmission: t56, 4speed auto
wont start
my camaro wont start but if i use a pair of pliers to jump the starter solinoid it will start. i think it is a ford solinoid because there wasnt enought clearace for the chevy one. i dont know if the solinoid is bad or the ignition switch. can anyone help me trouble shoot this problem. its on a carbed car
Old Sep 19, 2004 | 09:04 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Have you checked the purple wire that goes from the park/neutral switch to the starter solenoid. Better yet, have you checked the park/neutral switch?
Old Sep 19, 2004 | 09:17 PM
Engine: ls1, 4.0L
were might this switch be located so i can check?
Old Sep 19, 2004 | 09:19 PM
Engine: ls1, 4.0L
this is for a second gen camaro but i really need to get some answers thats why i came here and those 2nd gen camaro message boards kinda suck.
Old Sep 19, 2004 | 09:24 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If it is an automatic it will be located under the center console on the shifter assembly. If it is a manual it will be the clutch start switch on the clutch pedal.
Old Sep 19, 2004 | 09:31 PM
Engine: ls1, 4.0L
ok i'll check that. just to futher explain i put the key in and turn it to start but it dont crank or anything. its a auto
Old Sep 19, 2004 | 09:44 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Sometimes if the shifter is not comepletely in park or the switch is out of adjustment you will get that problem. Another thing to check is the ignition switch on the steering column under the dash.
Old Sep 20, 2004 | 03:54 PM
Engine: ls1, 4.0L
i thought on that neutral/park switch if it went bad u could start it in any gear?
Old Sep 20, 2004 | 04:23 PM
Engine: ls1, 4.0L
i looked under the dash for the ignition switch but there are three switches 2 towards the front and one towards the back
Old Sep 20, 2004 | 04:24 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It doesn't quite work that way, that is why it is called a park/neutral safety switch.
Old Sep 20, 2004 | 04:33 PM
Engine: ls1, 4.0L
i know what the park/neutral switch does but i thought when it went bad it would let you start the car in any gear but w/e
Old Sep 21, 2004 | 07:38 PM
Engine: ls1, 4.0L
i replaced the ignition switch today and that didnt fix anything so i am gonna try the park/neutural switch tomarrow
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
