choke light
Old Oct 8, 2004 | 11:21 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
choke light
ive had this car for five years and didnt know it had a choke light all the computers have been disconnected the carb has no electroics (never has) in fact it doesnt even have a choke ... this light is kinda bugging me ... if i have too i will pull the dash and get rid of the light bulb but im hoping someone here has a better plan ... thanks ... tao
Old Oct 10, 2004 | 08:43 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Why dont you just pull the bulb out.Remove the black gauge bezel & you will see the bulb in the pocket reach in & pull it out.
Old Oct 10, 2004 | 10:41 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
since i cant find the source i guess thats what ill have to do ... thank ... tao
Old Oct 11, 2004 | 08:03 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
It could just be grounded,causing to stay on.removing might be the safe thing to do till you find the cause.
Old Oct 11, 2004 | 09:28 PM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
try also unhooking the battery for about 30 minutes, it should reset the computer and then the light should go off. i did that when my check engine light came on, when i was working on it.
Old Oct 13, 2004 | 08:35 PM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
What's the voltage reading? On 82-85 cars, the "choke" light is really turned On when the Alt output voltage is low!!!!
Old Oct 14, 2004 | 02:03 AM
taonindo's Avatar
Car: 82 firebird
Engine: 406
in dash volt gage shows close to 15 volts at about 1200 rpm ... but i will check it tommorow with a meter ... thanks for the input ... tao
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
383cam
Sep 9, 2015 06:01 AM
TBRays98
Sep 6, 2015 05:05 PM
Jetmeck
Sep 4, 2015 12:29 AM
luvofjah
Sep 3, 2015 07:08 PM
