Firebird Gauge Swap Question
Old Oct 9, 2004 | 12:05 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
I never hooked the V6 tach back up when I did my V6-V8 engine swap since I knew it wouldn't be accurate anyway. This week I bought a 140mph cluster with an 8K tach out of an '86 T/A. I read the tech article on swapping the electronic speedo, but I searched and couldn't find anything on the tach.
Will the 8K V8 tach plug right into the harness as my 6K V6 tach did? I was going to use the entire cluster from the 86. When I compared the two, I also noticed the fuel gauge and oil pressure gauge are in the opposite locations from my '83 cluster. I'm thinking that might keep it from being a "plug-in" deal.
I need to know: (1) will the later-model V8 tach plug right in and work (if not, what needs to be modded? (2) Will the oil, temp, fuel and batt gauges plug right in (if not, what needs to be modded?). I'm running an MSD-6A box if that matters to the tach install.
Old Oct 11, 2004 | 04:12 PM
GarageToys's Avatar
C'mon... nobody has swapped later model gauges into an 82-84??? A bunch of people have swapped to the electronic speedos-- I'm sure some have swapped the whole cluster and not just the speedo head.
Old Oct 11, 2004 | 04:25 PM
cheyenne383's Avatar
Car: Huffy 10 speed ;)
Engine: My legs
Transmission: My wrist
Axle/Gears: Little spokey things
Hey there pal.... I know the tach will plug right in. Lemme look around for the other guages.
Take a pic of the back of the panel if you can, that'll help.
Old Oct 11, 2004 | 04:44 PM
Engine: My legs
By the way, the tach will only be as accurate as it was from the factory. The reading high is a GM thing. :lala:
Old Oct 11, 2004 | 05:20 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
You'll need to switch around some wires on the connectors.
I'm not sure of the original configuration - maybe you can write them down and send them to me so I can add them to the article - so they end up like this for the 86-up cluster http://www.hioutput.com/tech/circuits/86pinouts.html
Pete
Old Oct 12, 2004 | 10:40 AM
GarageToys's Avatar
Originally posted by cheyenne383
...Take a pic of the back of the panel if you can, that'll help.
I don't have a pic of the back of the '83 gauges because they are still installed. Here's the back of the 86:
Old Oct 12, 2004 | 10:43 AM
GarageToys's Avatar
...and here's a close-up of the ports where the connectors plug in:
Old Oct 12, 2004 | 05:40 PM
Engine: My legs
Just trace the circuits to each guage on each panel, if you send me close pics of each i'll do it when I get bored. Then switch the wires accordingly. I tried to display this technique with my superior MS paint skillzz, werd YO!!!
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
