Fuel Gauge problems...
Old Oct 17, 2004 | 03:07 PM
WickedTA's Avatar
Car: 85 TA
Well im startin to get tired of not knowin how much gas i have. I took off the top of the tank to check all the wires. Im also tryin to find the culprit of my fuel pump stopin when it wants to. then startin when it wants to. Anyway, back to the gauge. I found the wire that send the signal to the gauge. WHen i start the car or have it in the prime position it reads COMPLETLY full. When i put a test light on the wire it goes to half a tank. Which is about what i have in there from the looks of it. I thought it was bad ground ect... I held a wire on the signal wire then grounded the other side. Now my gauge reads empty. All the connections look ok. I followed the wire up to the kick panel and still the same thing on readings. I have no idea what else to try. Anybody?
Old Oct 17, 2004 | 10:51 PM
WickedTA's Avatar
Car: 85 TA
nobody???
Old Oct 19, 2004 | 10:47 PM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
Bad fuel level sending unit in the tank?
Old Oct 19, 2004 | 11:32 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You really need a multimeter to check the reading at the gas tank harness to see if the sender has any resistance (should be between 0-90 ohm depending on fuel level)
The gauge will peg full when a break in the circuit between it and ground is present and read empty when grounded w/zero resistance. The test light probably just gave a weak ground through the wire when you tested it causing the gauge to get a faint reading.
Old Oct 30, 2004 | 04:00 PM
breybok's Avatar
Car: 89 Iroc
Engine: ZZ4 Crate 350
Transmission: Art Car 700R4
Axle/Gears: 3.43
This is kind of the same topic, but anyways. Does anyone know is a fuel pumd & sender out of a tpi engine will work in a TBI.
Old Oct 30, 2004 | 11:13 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes, I have one in my 89 Iroc right now from a 91RS 305 TBI.
Old Oct 31, 2004 | 05:10 AM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
where is the cheapest place to get a NEW Sending Unit
Old Oct 31, 2004 | 09:06 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Check around with the local auto parts stores and price them out.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
R3500
Aug 17, 2015 12:16 PM
