Passenger Headlight Will Not Open
Old Nov 1, 2004 | 06:07 PM
dono420's Avatar
The passenger headlight motor does not open when I turn on the headlights.
Both lights turn on.
If I turn on the headlights and manually crank up the passenger headlight it will stay up, but once I turn off the headlights, both lights will close, meaning I have to manually crank up the passenger light every time it gets dark.
I think it might be a fuse, relay, or switch, but I am not quite sure.
Does anyone have any advice?
BTW, I checked into the TDS repair kit, but apparently it is only for '87 and newer.
My car info :
1986 Firebird Trans Am
5.0L TPI
Old Jan 11, 2005 | 02:40 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
This is kind of old but I'm having the exact same problem. However, my switch is also broken (I think) so I need to find a replacement for that first.
I'll let you know what happens, though.
Old Jan 12, 2005 | 12:22 AM
H0TR0Dn's Avatar
Car: 88 Formula 350
Can you hear the motor moving when you turn on the light? On my 88 you could hear the motor working, light on, just would not raise. I got the kit from TDS, fixed problem.
BlueIroc-Z
Jun 9, 2019 03:22 AM
GTAman
Mar 15, 2019 11:40 AM
Todd84Z
Sep 4, 2015 08:02 AM
andy74
Sep 3, 2015 08:41 AM
Fronzizzle
Aug 17, 2015 02:52 PM
