Besides alternator, what could cause battery to not charge?
Old Nov 9, 2004 | 09:24 PM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
Its a brand new battery, had the same problem with the old one....What, besides the alternator, could cause it to not charge? Just replaced the cables too! (thought it might fix it, but guess it didnt...)
Before I go replacing the alt., what should i check?
Old Nov 9, 2004 | 09:55 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Fusible link to the starter solenoid.
Old Nov 10, 2004 | 05:22 AM
where/how do i check this? Thanks
Old Nov 10, 2004 | 10:04 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The red wire that runs from the alternator plug has a fusible link down at the starter solenoid. There is also a fusible link in the battery cable that runs from the post on the alternator to the battery. Also check the fan fuse in the fuse block, that is where the tan wire goes. To check the fusible links, just pull on them lightly and if they stretch they are bad.
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
drumstixer
Sep 29, 2015 03:02 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
