Rear hatch wireing diagram request
Old Nov 10, 2004 | 04:00 PM
Rainman's Avatar
Car: 1989 Firebird Formula
Transmission: WC T-5
Axle/Gears: Moser 12 bolt, 3.73 gears
Like the title says im tryin to find a wireing diagram for the rear hatch motor. i have a chiltons book but either im blind or they suck cause i cant find anything about the rear hatch in there. I bought the car with the hatch not workin but i have used the TDS deluxe rebuild kit(which worked great) and bought a new striker sensor and im about to buy a new reverseing switch and i want to make sure i have the wireing right.
as a side note if anyones hatch motor doesnt work TDS has everything you'll need so check them out.
Old Nov 11, 2004 | 09:47 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
No wiring diagram exists for the hatch pull-down unit that I'm aware of. Regardless, here's how it is wired; the red/white stripe wire is +12v and connects to the blue wire. The black wire with ring terminal is ground and attaches to the ground location just below the hatch pull-down unit. The reversing switch has a tab that slides into a channel on the clear plastic motor housing. The reversing switch has two connectors that snap onto the terminals on the motor, then it is held in place with a single Phillips-head screw. The striker-sensing switch contains all the wiring for the hatch pull-down unit. The switch attaches adjacent to the latch with a single screw. The white connector of that wiring bundle with blue, white, orange & brown wires plugs into the reversing switch (provides power to the motor through the reversing switch). A relay plugs onto the relay socket. The white wire with small black connector on the end isn't plugged into anything on your car (1986-88). Beginning in either 89 or 90 the white wire plugs into an orange with black stripe wire and powers the hatch interior light. Yours is turned on/off with a manual switch. If your car has a hatch solenoid release, there is a black wire that supplies +12v from the hatch release switch through a relay. Be sure that you have a ground wire running from the 10mm screw (that attaches the hatch release solenoid to the hatch pull-down unit) to the ground location below the hatch pull-down unit. If that wire is missing the solenoid won't fire because it is electrically isolated from ground by the plastic guides in the track.
PS: The contact pad just to the left of the latch and spring-loaded contact pins on hatch have NOTHING to do with the hatch pull-down unit. They power the HMSL (high-mount stop light aka third brake light that is in the spoiler) when the hatch is closed.
Lon Salren
Top-Down Solutions
Old Nov 11, 2004 | 04:42 PM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
here's what i have. Good luck!
Caspar
Jun 19, 2016 11:19 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
