Wiring Diagram for Rear Defrost Button
Car: 88 IROC
Engine: 5.O TBI
Does anyone have the wiring diagram for the rear defrost button on an '88 IROC? (The button under the lighter)
Any help would be great!!!
Car: 88 IROC
Engine: 5.O TBI
Ok,
I now understand where Some of the wires connect. Some I still Cannot locate where they Connect under the dash.
Purple/white wire - Connects to the hatch Strut.
Black wire - ground
Oranges/Black wire - Connects to the junction box under the kicker panel.
Pink/Black wire - Connects into the back of the fuse Panel???
Gray wire - ????
Any help with the Gray - Pink/Black wires on where they are to connect??
Black wire - ground
Gray wire - ????
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
the diagram says it goes from the fuse block to pin 'E' i'll see how my car my car is wired and see if i can help u....
Car: 88 IROC
Engine: 5.O TBI
The diagrams also mention the fuse block for pin E (Pink/Black wire) and pin A (Gray wire) but, where is the fuse block under the dash?
Does pin E and pin A go to a different fuse block?
I have the complete stock harness and just need the location of fuse block to install the harness.
Car: 88 IROC
Engine: 5.O TBI
Originally posted by Trickster
The fuse block is under the dash by the drivers left knee. Did you get the info I sent you last night?
Yes I did receive your email, thank you !!!!
So, the following wires all hook into the fuse block under drivers side kick panel?
pin B - Oranges/Black wire
pin E - Pink/Black wire
pin A - Gray wire
Or Pin E and A hook to the back of the fuse panel? That's above my left knee.
Are there photos of these wires connected to the fuse block?
Car: 88 IROC
Engine: 5.O TBI
Ok,
It has set in with this final diagram.
Just need to connect both connectors into the back of the fuse block. Will each connector only fit into a specific port?
AkDrifted
Aug 17, 2015 07:45 PM
