wacky tach?
Old Nov 12, 2004 | 06:42 PM
RedWagon42's Avatar
wacky tach?
my tach has never worked right since i got the car... i used to work if i divide the rpm it was on by 3 and it gave a pretty close estimate. i switched from tbi to carb and now its just pegged out. does any one have any advice?
i thought i saw a tach repair/troubleshooting thread like 2 years ago, but i cant find it?
Old Nov 13, 2004 | 11:11 PM
Vader's Avatar
It is likely that the calibration resistors in the tach electronics are failing (changing resistance) due to age, or the adjacent filter capacitor is suffering from insulation breakdown. The proper fix would be to install new precision resistors and/or a mylar capacitor. The OEM resistors are in a DIP, which makes replacement a bit of a chore - Not impossible, but a challenge.
EDIT: Did you try a SEARCH? I found this in about twenty seconds:
https://www.thirdgen.org/techbb2/sho...h+AND+resistor
And this:
https://www.thirdgen.org/techbb2/sho...hreadid=114057
$750 L98
Feb 1, 2025 02:25 PM
86maro_252
Oct 10, 2015 06:52 PM
Eric-86sc
Sep 28, 2015 11:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
