Dome Light Problem
Old Nov 18, 2004 | 06:34 PM
MC Ray's Avatar
Dome Light Problem
The dome light on my '84 Camaro doesn't go out when the doors are closed. The dimmer switch isn't on, unless the wiring there is messed up. The courtesy lights down by the kick panels turn off when the doors are closed, so I don't think that's the problem either. Where/how should I look for the cause?
Old Nov 18, 2004 | 10:43 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Do you have the two reading lights in your car? If so you might have a short to ground between them and the dome light.
Old Nov 19, 2004 | 02:11 AM
MC Ray's Avatar
I have the overhead console thing with the one map light, but there's no bulb in it.
Old Nov 19, 2004 | 09:56 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
SO you have the dome light and the map light, correct?
Old Nov 20, 2004 | 04:18 AM
MC Ray's Avatar
Yes, dome light and map light.
Old Nov 20, 2004 | 08:52 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There is a ground wire that goes between the map light and the dome light. Check that to see if it is grounding out and causing the dome light to stay on.
1992CamaroGirl
Dec 25, 2017 08:45 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Omega
Aug 10, 2015 12:46 PM
