91 camaro, wiring diagram needed
Old Oct 30, 2011 | 05:00 PM
  #51
procharge87's Avatar
Re: 91 camaro, wiring diagram needed
trying to fix my 91 rs camaro that does not want to start tried jumping the starter and cranks then but not with key was thinking it might be starter enable relay but cant find it any one have pic of it
Old Oct 30, 2011 | 05:28 PM
  #52
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Your starter relay should be mounted behind the left kick panel on the drivers side under the dash
Old Oct 30, 2011 | 06:56 PM
  #53
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
sounds like you have a VATS problem. try turning the key to the on possition and jump the starter again. if it cranks its
an issue with the relay, if it doesnt, then its a VATS issue.
Old Oct 30, 2011 | 07:02 PM
  #54
yeah i did that it will turn the motor over but no start gonna get a relay and see whats up
Old Oct 30, 2011 | 07:15 PM
  #55
travis401's Avatar
Car: 91 Camaro RS
did you jump the starter with the key on and it didnt start? if the answer to that is yes, then a new start enbale relay isnt going to fix it. you need to do a search on VATS and see what all is involved in diagnosing it and either fixing it or bypassing it.
Old Oct 30, 2011 | 07:16 PM
  #56
travis401's Avatar
Car: 91 Camaro RS
by "if it cranks" i ment "if the car starts" sorry for the confusion
Old Oct 30, 2011 | 07:17 PM
  #57
cool thanks alot
Old Jul 14, 2012 | 09:30 AM
  #58
rocn7roc's Avatar
Thanks for the diagrams!
Old Jul 14, 2012 | 12:55 PM
  #59
oramac91's Avatar
[QUOTE=procharge87;5081879]trying to fix my 91 rs camaro that does not want to start tried jumping the starter and cranks then but not with key was thinking it might be starter enable relay but cant find it any one have pic of it[/QUOTE you find the relay.Had same problem.Relay fixed it. If sitting in the car ,it the panel by your left foot.Right below the hood release.
Old Aug 14, 2012 | 10:16 AM
  #60
monte0185's Avatar
Car: 1991 Camaro Z28
Engine: 383
Transmission: tci 700r4
Axle/Gears: 373
Thanks for the wiring diagrams!!
Old Nov 7, 2012 | 09:41 AM
  #61
PurpleG20305TPI's Avatar
Car: 88 Chevy G20 Wagon Wheel Conv Van
Engine: 91 camaro z28 305 tpi 77k miles
Transmission: TH400
Originally Posted by IROCKman
Hi i have a 87 irocz tpi 5.7 could you send me a wiring diagram of the three relays on fire wall driver side maf burn off maf power and fuel pump relays i want to make sure which relays go to what wires thanks so much it would really be helpful went to chev dealer today and they were no help at all thanks again
hope this helps....
[URL=""]
Old Oct 9, 2022 | 03:49 PM
  #62
Lawman86's Avatar
Car: 1991 Camaro RS
Engine: 400 SBC
Transmission: TH400
Axle/Gears: 3:73
Originally Posted by Trickster
They will be in PDF format, I will also try to include locations of components.
hey good sir could you send it to me. Mines a 91, I’m building a blown race car and this one has all the factory wiring and I am trying to figure out how to hook up a ignition switch, then the start switch. Our 86 camaro was gutted so it made our life a lot simpler
Old Oct 10, 2022 | 09:11 AM
  #63
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
If you are just looking for wiring diagrams AustinThirdGen.Org is a great resource
Old Oct 10, 2022 | 09:28 AM
  #64
Lawman86's Avatar
Car: 1991 Camaro RS
Engine: 400 SBC
Transmission: TH400
Axle/Gears: 3:73
i was looking to see if that one member still had the direction on what wires to use under the steering column for toggle switches. I’ve got the Austin website, I’m going to be getting rid of some wires but I want to know what wires I need for 1. Ignition, Accessory, and Start. That’s what I was looking to see since I am working with the wires off the steering column
Old Oct 10, 2022 | 10:22 AM
  #65
91banditt2's Avatar
Engine: 5.7 HSR
Looks like Trickster has posted on here in about 3 years, maybe someone else that was posting 10-20 years ago can reply. Your better bet may be to post a new thread.
Old Oct 10, 2022 | 10:26 AM
  #66
Lawman86's Avatar
Car: 1991 Camaro RS
Engine: 400 SBC
Transmission: TH400
Axle/Gears: 3:73
I know it would be nice if they still got the notifications or emails from this. I hate starting new threads over an old subject, but this was only emailed to him, I just hope they don’t gripe about a new thread
IROCZ1989
Jan 24, 2016 03:55 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
sonu1975
Aug 11, 2015 08:38 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
