!!!!emergency, Need Help!!!!!!!!!!
Old Nov 24, 2004 | 06:28 PM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
OK, I HAD A PAINT SHOP CHANGE MY FRONT BUMPER AND REPAINT MY CAR, WHEN I GET IT BACK , I GO TO TURN ON THE LIGHTS AFTER I HAVE IT HOM AND EVERYTHING, AND I MEAN EVERYTHING GOES DEAD, INTERIOR, DASH, HEAD AND TAIL LIGHTS, BUT THE CAR WILL STILL START AND RUN. DOES ANYONE HAVE AN IDEA OF WHAT CONTROLS ALL OF THE LIGHTS IN A 86 IROCZ. I ALREADY HAVE CHECKED THE UNDERDASH FUSES AND THEY ARE PERFECT, IS THERE SOMETHING IA M MISSING? IT THANKS GIVING AND EVERYONE IS CLOSED. ANY HELP WOULD BE GREAT
Old Nov 25, 2004 | 07:36 PM
86irocznj's Avatar
wow!
sounds like a bind ...when you start up the car does it say your left or right blinker is on when its not? ...if so its a wiring problem ...my camaro has the same issue but i bypassed it
Old Nov 25, 2004 | 10:42 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Check all the grounds up around where they painted and did the body work.
Old Nov 26, 2004 | 07:24 AM
well it doesnt show anything when i turn the car on, i am gonna go throught the grounds today but after thinking about it when i went to pull the light switch the lights came on for a second and then shut off, that is why i thought it was a fuse, is it possible that the light switch could have gone out, does it control enough to even make the interior lights go out with the dimmer part of it? i was thinking that could be a possibility, does anyone know the body wiring good enough to say if it could just be the 20 year old switch went out?
Old Nov 26, 2004 | 10:03 AM
update! i went out side today and tried everything and all the lights worked like a charm except the foglights are not working. they worked before these dumb-dumbs touched it but anyway, so it is somewhere in the foglight wiring from what i guess , so ill be checking all of that today plus going back over my front end grounds
Old Oct 25, 2006 | 04:50 PM
johnny90's Avatar
The blue wire on the drivers side of the car by the strut that runs to the relay by the hood hinges check that wiggle the wires and that black connetion on the blue wire makes my fog lights work every time on my 90
Old Oct 27, 2006 | 03:52 PM
dubcity's Avatar
Car: 85 Camaro iroc
Engine: 305ci HO
got any pics of your car?
Vintageracer
Jan 10, 2020 05:33 PM
Warlocksirix
Sep 3, 2015 12:26 PM
smooth
Aug 18, 2015 06:34 PM
Bob88GTA
Aug 18, 2015 03:31 PM
jj4
Oct 9, 2000 01:31 PM
