ACC fuse problem
Car: Bitchin' 92 RS
ACC fuse problem
Ok, here is the problem, I have several things I know of running off the ACC fuse, the cig lighter, CB, dome and curtesy lights. And the fuse blows like everyother day, and I also have to unhook the battery to put a fuse in or it will blow.
I need to know know if the tag light is also on that fuse, cause I think there is a short in my tag light wiring.
the tag light is the only thing I can think of thats shorting.
Kyle
Kyle
"Tag light?" Do you mean the rear license lights? Those are proteceted by the 20A TAIL fuse, not the ACC fuse.
Take a look inside the ash tray to make sure the metal liner is not pinching a wire. Remove the lighter itself to make sure there are no foreign objects (like screws or coins) in the lighter socket. If everything is good there, try installing a new fuse with the lighter out of the socket.
Other loads connected to the ACC fuse that might be worth looking at are:
Rear cargo well lamp;
Map/reading lights;
Power antenna and antenna relay;
Horn relay (big possibility);
Dome and courtesy lamps;
Rear power hatch release and pull-down motor.
Map/reading lights;
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The tag (license) light is on the "TAIL" fuse and is only functional when the lights are turned on with the light switch. Here is a schematic of the "ACC" fuse showing the items that are connected to it.
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
When an electric motor is jammed up (the output shaft can't turn), It will draw too much current (and get hot) and blow fuses, sometimes right away, somtimes after a few hours.
Looking at Trickster's print, I see power seats and mirrors as possiblie problems. Do you have these? Do they work OK? Anything getting hot with a good fuse?
Car: Bitchin' 92 RS
no, no power seats or mirrors, but the underhood light, the wire got the insulation fried off in a small fire, if the wire is touching metal somwhere it would cause it to short, right?
