Electrical problem part 2...
Old Dec 4, 2004 | 02:20 AM
POS350Z's Avatar
Car: 89 Iroc
Engine: L9-to small
Transmission: 6 spd
So if you have a short in a wire bundle..could it cause damage somwhere else in the same bundle????
350Z
Old Dec 4, 2004 | 10:44 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes especially since the car manufacturers like to add splices to wires to run sub systems off of one wire.
Old Dec 4, 2004 | 12:21 PM
POS350Z's Avatar
Car: 89 Iroc
Engine: L9-to small
Transmission: 6 spd
cool....there is a short/grounding problem in the headlight/turnsignal/fog light wire harness on my POS. Looks like there was heat damage from a header fire I had years ago. The harness connector (where it plugs into the firewall) was warped and the black tape/wrap that was used around the connector looks like it was melted into the connector....when we pulled it off there was black plasticy goo in it. We ran some tests using a volt meter and found that at least one of the ground wires was getting power from a pwr wire...somwhere....I'm gonna replace the whole harness.....think I sould go with a factory new piece or somthing from painless wiring???
Thanks!! 350Z
86IROC112
Aug 17, 2015 02:00 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
