fog light install on a 92 rs
Old Dec 9, 2004 | 12:38 PM
costill91Z's Avatar
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
Axle/Gears: 4.30 Dana 44 Rear 10 bolt front
ok, i have a set of fog lights from my old z that i want to install on my rs, my question is, for the people who've done this before:
Is there already a connector for the switch located in the dash, b/c when i had my dash apart to do my heater core i noticed an extra wire and connector that i didn't have any where to hook up to. i have the wires from the old setup (everything from the fog lights back to the firewall) if so, does it already have power to it, or do i need to run power still?
I'm not real big on wiring and electronics, but if I'll try to accomplish this myself if I can. Any tips or suggestions would be GREATLY appreciated
thanks
-costill
Old Dec 11, 2004 | 03:09 AM
costill91Z's Avatar
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
Anyone...
please help, i'm retarded at this stuff.
I bought a factory fog light switch to mount for a factory look,
but what is the easiest way to go about this and is the connector already there, or did I not hook something up?
A wiring diagram or anything would be helpful.
thanks
-costill
Old Dec 17, 2004 | 04:52 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Shouldnt be to hard to figure out if you have a simple Ohm test set. With your test set, on your donar car, find the correct pin positions at the firewall connector to the fog light ends. Compare your driver car's female connector to see if it's wired the same as the donar car. You may find that the interior wiring is already there and you may just need to add the fog light plate and switch to your dash.
jaridjohn
Jul 8, 2024 03:49 PM
TheExaminer
Aug 26, 2015 04:59 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
