electrical problems need help please!!!
Old Dec 23, 2004 | 11:32 PM
rs82's Avatar
Car: 1988 RS Camaro
I have had my battery tested and they said it was good and has long life, and I took my alternator had it tested they said it was good but they gave me a new one anyways. I put it back in drove for awhile and the battery guage started dropping then the lights dimmed, the cd player went off guages stopped working and the car died. The battery dosn't die when car is parked only when I am moving. I need help on what I should look at or replace etc. I am a painter not a very good mechanic and need help. Thanks.
Old Dec 24, 2004 | 01:40 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
did you cheak the wires going into the alt make sure they are not frayed and have a good conection the wire might be beer at a point and when you are driveing it could be grounding out so you want to cheak for that also. hope this helps
Old Dec 24, 2004 | 03:07 PM
Cooper's Avatar
Car: '89 GTA
Axle/Gears: 3.45
Also check for loose ground stratps to the body and block.
Old Dec 24, 2004 | 07:25 PM
rs82's Avatar
Car: 1988 RS Camaro
Thanks guys, I'll check those wires and let you know.
toones
Jan 6, 2016 06:00 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
