84" Lights wiring schematic
Old Dec 27, 2004 | 09:35 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
The lights from the guages to the headlights and turn signals are acting up a little and i think its just some faulty wiring. Here the deal, turned headlights on today, right one good, left one extremely dim, so i swapped sides, same thing, left turnsignal dont work, but they do work on hazards, but front ones are not in sequence, the parking lamps that is, right side fender lights stays lit, and never flashes, and finally sometimes when you turn on the headlights, it makes the guages go crazy, and if you push really hard on the center of the cluster the start working right.
So does anyone have a schematic (spelling) for a 84 camaro, 305 HO.
thanks
Kevin
Old Dec 27, 2004 | 11:15 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Uh Huh!! I will e-mail them to you tomorrow sometime.
Old Dec 27, 2004 | 11:18 PM
Engine: 383, L69
That would be great, i dont need them tonight anyhow, thanks in advance Trickster. I prob got a few shorts somewhere, as my choke light is on too. Gonna swap the alternator tomm.
Kevin
Old Jan 8, 2005 | 11:09 PM
84 Z28 5.0 HO's Avatar
Car: 84 Camaro Z28
Engine: 305 L69
For the gauges, Same thing happened to me. On the film traces in the back of the gauge cluster one or more sections had a hairline crack. All i did was solder a wire jumper across the brake. That fixed it real quick. Also check for corrosion on the headlight connectors. My daily driver aspire's right head light was dim. turned out there was some corrosion. clean them with some electrical contact cleaner and lube them up with dielectric grease. Worked wonders
TheJoeY88
Dec 31, 2016 07:30 PM
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
