-another battery drain?
Old Jan 5, 2005 | 03:05 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
ok i hooked up a meter in line with my battery and i showed .89ma. i started pulling fuses and it dropped to .21 when i pulled the "ctsy" fuse. i think thats what it says. its hard to read.
the only thing i could find that doesnt work now is the horn.
1. if the horn was draining the battery wouldnt it be blowing?
2. anyone know what that fuse went to originally? from top to bottom it is stop haz
tail
ctsy
3. the meter should be 0 if nothing is draining battery right?
greatly appreciate any advice.
Old Jan 5, 2005 | 08:24 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The "CTSY" fuse is the same as the "ACC" fuse in later models. It powers the cigar lighter, dome lights, CTSY lights under the dash and a multitude of other items.
1. no, it might be a bad ground.
2. see above paragraph.
3. no, normal reading is around .2 AMPS
Old Jan 6, 2005 | 08:16 AM
hoogabooga's Avatar
Engine: 427 454
Transmission: TH400
thank you sir. now i know where to start.
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
drumstixer
Sep 29, 2015 03:02 PM
raymondandretti
Sep 27, 2015 06:43 PM
