bosch spst relay trigger voltage
Old Jan 10, 2005 | 01:00 PM
91Z28-350's Avatar
Does anyone know the minimum voltage for an SPST relay to trigger?
I'm fighting starter issues. My purple wire is getting around 9v and more often than not my starter doesn't turn over. I will do some rewiring first to see if I can bring that voltage up, but if that doesn't work I may hook up a relay to the battery and trigger on the purple wire to feed battery voltage to the starter.
I think 9v should be able to trigger the relay, but I'm not sure.
Old Jan 10, 2005 | 03:27 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
The "Bosch" style relays that I've played with like this need 8V to pull-in 6V min-holding. Note that "Bosch" is in quotes. There are allot of "Bosch" style relays out there and they WILL differ from manufacturer to manufacturer.
I would fix whatever is broken though. If your just seeing 9V at the starter, I would check for bad motor grounds first and go from there.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
HoosierinWA
Oct 7, 2015 10:15 AM
