How To properly Vent battery in wheel well
Old Jan 12, 2005 | 12:42 AM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Whats the requirements to properly vent a battery that has been relocated to the rear well, i would like to have a set up that i could run any type of battery be it sealed or not, but standard size for the F-body.
Do you just basicly drill a hole to the out side of the compartment, and run a hose to it? If so there really isnt much going on pushing the gasses from the battery out of the area, I belive hydrogen is made from discharging a battery, witch will rise, so vent above the battery holder?
Old Jan 12, 2005 | 10:18 AM
Chilo's Avatar
Car: 91 Z28
Engine: 355 TPI
Transmission: Streetfighter 700r4
1st: Running a hose to the outside of the car won't do any good unless the battery inside a sealed battery box.
2nd: If you will be using a sealed box, then it doesn't matter where the hose will be located on the box. The gases will eventually find their way out of the box through the hose.
I would just probably use a dry cell, deep cycle battery instead. No more problems with gases. Just my
Old Jan 12, 2005 | 10:57 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Like Chilo said, you need a sealed box and a hose to the out side......
Old Jan 12, 2005 | 11:28 AM
Car: 87 Firebird
Engine: 5.3 76mm
I was planing on running a sealed box, like the 2ga kit from summit, but wasnt sure of the vent part of it, but i guess if it will eventually find a way out and be considered safe, then all should be good.
Old Jan 12, 2005 | 05:14 PM
Dr G's Avatar
You should consider the NHRA approved Moroso relocation box and wires.
If it's in the rear well you may not need to drill a hole for the vent tube. You can run it from the box, through a neat little hole made in the carpet and then out an existing drainage hole.
I'd definitely still advise always buying a sealed battery, such as an Optima though.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
