Headlight Hi/Low beam problem
Old Jan 13, 2005 | 07:35 AM
necromancer1967's Avatar
Car: 88 Chevy Camaro IROC-Z
Engine: L98 5.7L 350 MAF TPI
Transmission: TH700R4
Axle/Gears: BW 9bolt/3.27 gears
I have a 91 camaro RS with cruise control. The Hi/Low beam switch will not click back to low beam. I have looked all through the Haynes manual and even searched on-line for instructions on replacing the switch as well as removing the turn signal arm from the steering column with absolutely no luck. Anyone able to direct me on how to replace these Items, or have knowledge of who who sells a service manual containing this repair?
Old Jan 13, 2005 | 03:04 PM
17wth85z28's Avatar
Car: hmmm, camaro site.....
Engine: 305.... TEAR
Transmission: t-5 soon
From what I can tell, the switch is actually underneath the dash. Its on the Steering column. Look for a little metal rod, on the driver door side of the column. Best bet is to lay upside down on the seat and look underneath.
Old Jan 14, 2005 | 05:26 PM
srdynamics1's Avatar
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
I had the same problem with my switch. Broken switch got stuck on high beam.
To get it back to low beam I pulled up on stalk and at the same time back.
Another way is to pull the steering wheel down past its lowest setting and do the same. Worked for me, though yours may be broken in a different way.
Old Jan 14, 2005 | 06:57 PM
Big AL91's Avatar
Car: '91 Camaro
Engine: 305ciV8LO3TBI
Transmission: Auto.
Into adjusting dimmer switch with info from search on these forums, ie dimmer switch. Good Luck
Old Jul 20, 2006 | 08:53 AM
Found it. Rests on top of steering column and held in by two hex head screws. guess it has a tendency of loosening after time. I loosened screws and slid switch up to meet the rod from the lever actuator, retightened and it worked just fine. It was alot easier to drop the steering column. Gave better access. Thanks a million fellas!
GTAman
Mar 15, 2019 11:40 AM
1992CamaroGirl
Dec 25, 2017 08:45 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
