serious problem
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
serious problem
ok so i finished wiring my gauges in the other day. they look sweet. but the only problem is now when i accelerate into the higher rpm range my gauges to crazy seperate from the the car is accually doing. and then there is like a loss of power to the engine and thats when i let off the throttle. mostly my tach and speedometer are the ones that act up. any suggestions i think its cus i messed up in the wiring. who know any suggestions about where to start looking?
Car: 1991 Chevy Camaro
Engine: 305 TBI
How many gauges did you hook up, and what company makes the gauges? Exactly where did you tap into for the wiring for the gauges?
Why do you think messed up the wiring?
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
i checked my wireing and there where no mess ups so thats not the problem. autometer, 3, i plugged them inter there ignition terminal on the fuse box. and for the lighting a plugged them into the terminal right next to the ignition terminal. the other day i disconnected all the gauges and ran the car and it still does it. i know its an electrical problem cus i took my friend for a ride who knows a lot more about cars than i do and he told me that its electrical. so i dont know where to start. i already had my charging system checked out and everything is normal. i just dont know where to start.
