how many wires to the starter
Old Jan 21, 2005 | 09:18 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
how many wires to the starter on a 84 l69 im counting3 total bat a small one to the s and another wire that goes to the bat one. its a bosch starter it clicks but it doesnt turn over it wont rotate just clicks away. im so confused. whats the problem when i hotwire it it turned over just the starter i used a bat charger and a screwdriver but now that its in the car it just clicks what gives. am i missing a wire somewhere.
Old Jan 21, 2005 | 09:36 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello jocww,
From looking at my schematic for your car, you should have four wires and three connectors. One big wire from the battery, two fusible links in one terminal lug, and a small purple wire going to the small terminal marked "S". The purple wire goes to the Park/neutral switch on the shifter if it's an automatic and the Clutch safety switch on the clutch pedal if it's a manual. Have you checked the charge on the battery in the car? If less than 10 volts it won't work, I have also seen batteries that show 12 volts on the meter that have "0" for amperage.
Old Jan 21, 2005 | 09:45 PM
jocww's Avatar
correct amt of wires i have 2 wires going intoa single circle lug and its a big one i put it with the bat terminal and the purple is in the spot marked s i didnt put anything in the terminal marked r
thanks trickster.
Old Jan 21, 2005 | 10:07 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Old Jan 21, 2005 | 10:36 PM
jocww's Avatar
so if i have everything hooked up right howcome it just clicks and wont turn
Old Jan 21, 2005 | 10:49 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Have you checked to see if it might need some shims installed? also do you have the bat wire and two fusible links connected to the top post on the starter solenoid and that strap from the starter connected to the lower post on the solenoid. Have you also checked the voltage at the starter solenoid as someone trys to start it?
Old Jan 21, 2005 | 11:48 PM
jocww's Avatar
no i didnt think of shims as its the same flywheel same starter. the strap is connected to lower part of the starter. the 2 fusible links and the bat are tied to the top post. no i havent tried to check the voltage yet. is it true
ok put the DVOM on the 20 VDC scale
put the red lead onto the lil wire
and the black lead to ground
try to crank the engine with the key and see if the voltmeter shows 12vs
if it does then something is up with ur wiring going to the starter from the solenoid
if it doesnt then the problem is in the wiring coming from the ignition switch
Old Jan 22, 2005 | 12:15 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Basically. when you do this and turn the key you will get a drop in battery voltage due to the load being put on it. If it goes below between 9 & 10 volts then you have a bad battery. Another way to check the draw on the battery is to put a meter across the battery terminals and check the voltage drop as the key is turned just like above. Then check to see how fast the voltage goes back to 12 volts. If it is slow to go back, replace the battery. To check for voltage from the ignition switch, take the purple wire from the small post and put the meter across it and a good ground and have someone turn the key as you check the voltage. If things are okay it should be 12 volts.
Old Jan 22, 2005 | 12:21 AM
jocww's Avatar
brandnew battery so that should be good. do you think that it is shorting out somewhere. when i took the l69 out it started like a champ. its starting to make me mad. another big bump in the road.
Old Jan 22, 2005 | 12:37 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Did you check all your grounds on the back of both cylinder heads?
Old Jan 22, 2005 | 12:42 AM
jocww's Avatar
negative i didnt know i had to. how many grounds am i suppose to have.
Old Jan 22, 2005 | 01:18 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Battery to block (the big cable.. hopefully obvious )
Battery to chassis (8 - 10ga wire)
Block to chassis (braided strap from rear of head to firewall)
Old Jan 22, 2005 | 01:36 PM
jocww's Avatar
so if i dont have one of those 3 the car will not turn over. i dont want it to start i just want the starter to turn as i dont have the distr connected tot he wires.
Old Jan 22, 2005 | 01:59 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The car won't start with just the starter alone, it would need for the distributor, plugs, coil, & ignition module be connected as well.
Old Jan 22, 2005 | 10:20 PM
jocww's Avatar
i kno now all i have to do as it was a bad solnoid is to find the hot wire for the dist. and it will fire then i just gotta get the cooling done and re plumb a fuel line o and do you guys know how to bleed a slave cylinder
Street Lethal
Apr 30, 2019 12:14 PM
Caspar
Jun 19, 2016 11:19 PM
Accerrito22
Aug 23, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
