Fog light wiring
Old Jan 22, 2005 | 10:14 AM
jmp91rs's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Fog light wiring
I have a 91 RS that I'm in the process of adding factory fogs to. I've found all of the connectors on the factory harness under the dash(relay, switch, fuse), but haven't found the pigtails and connectors to go to the lamps themselves. Are they in the factory harness on a RS, or do I need to splice into some wires with connectors?
Old Feb 5, 2005 | 11:07 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I ran new wiring on my RS, sorry I can't be of more help. You can search my ID and see what I did. BTW, where did you find the factory plugs on your car? I'd like to find mine.
Thanks!
Ed
Old Feb 6, 2005 | 10:24 AM
jmp91rs's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
I could never find the connections to the lights themselves in the headlight harness, but i found the connector for the switch taped beside the gauge cluster right under the headlight switch. The plug in for the relay was up under the dash on the drivers side, mine was just hanging in there. It's just a standard five pin relay plug. I just wired them up yesterday with new wire tapped in right behind the switch through the firewall and up to the lights. Hope this helps. Let me know if you have any more questions.
jaridjohn
Jul 8, 2024 03:49 PM
TheExaminer
Aug 26, 2015 04:59 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
