Vss Info!
Old Jan 23, 2005 | 12:41 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
Vss Info!
after searchinfg for days, ive found (kinda) what all the different part #'s are for on the VSS.
hooking up a 4th gen speedo and i need the tailshaft mounted VSS and buffer box from the 86-89 firebirds.
d9a d9b and d9e are the options
d9a has a white connector, designed for automatic trans with a 40-45 tooth driven gear
d9e appears to be stock replacement for t5 (unsure of the gears)
d9b has a black connector, designed for automatic trans with a 34-39 tooth driven gear.
now my delima, i order the D9A from adcance.... pic showed a white connnector.... perfect. i get it.... it says "34-39" right on it. im assuming this means for 34-39 tooth gears.
well my 45 gear slips on it, so will it work, or will my speedo be off. you think they could be calibrated for a certain # of teeth and thats it, or just some sales related garbage?
hope ive shed some light, seems this is a sore subject.
if anyone has access to there vss, regardless of color.... do you have a white one that reads "40-45", or a black one for that matter?
they said i could return it, but hate to have them order another to have the same results.
if anyone might have a white connector vss that reads "40-45" ill take it off your hands.:hail:
everyone confused now?
Old Jan 23, 2005 | 01:56 AM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
Re: Vss Info!
Im using a 34-39 drive tooth count vss along with a 41 tooth drive gear. The bar of the VSS that the drive gear slips onto is a little short and doesn't go all the way through the gear. From what I was told when I did my swap, the only difference with the 2 different VSS for the auto is the length of that bar/shaft of the VSS, where the 40+ vss has a longer one the 34-39 has a shorter one. My car has been running since august with the mismatched 34-39 series VSS and 41 tooth drive gear and the speedo has been accurate.
and by the way, the connector of mine is black and it came from a '92 tbi
Old Jan 23, 2005 | 11:56 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
thanks for the info, learn something new everyday.
when you say it doesnt go all the way through..... my gear is flush with the bar sticking out of the VSS... i dont see a problem with it, dont know why it would need to be longer.
if i ever get this speedo thing situated, i can get my gauges in and work on modifying the 4th gen a pillars to fit.... and actually make it look decent.
Old Jan 23, 2005 | 12:34 PM
Transmission: 4L60e
Axle/Gears: 9 bolt
I don't know why either but thats how mine is. My 40+ gear is longer then the 34--39 for some reason.
What else do you need to know to get it working? Be sure to post how you do the pillars. Ive been using my old pillars until I get some extra $ and time to pick up some 4thgens. ALso been driving aroung with no top dash pad. haven't felt like dealing with that yet.
Old Jan 23, 2005 | 12:45 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
ive got 2 sets of a pillars at the moment. i was gonna cut it off at the T top mount and push it up to the factory 3rd gen one and run some black trim screws on the roofline.... shouldnt be too noticable. ive been hacking off material on the front to get them to sit at the windshield for a factory look and cut too much.... oops.
time to start over. im too picky to go with it not half way right.
i might have a set for sale if i dont mess these up.
ill get rid of them cheap, i dont have much in them.
thanks for the tips.
if the 34-39 and the 40-45 vss send the same pulse, i dont see why i couldnt use either.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
