temp gauge problems
Old Jan 23, 2005 | 02:33 PM
karsh305's Avatar
Car: '84 Camaro
Engine: 305 cu in
temp gauge problems
I have an '84 camaro that came with the instrument cluster with the idiot lights and big fuel gauge. I got a cluster with a tach and all gauges from an '86, and when I installed it, all of the gauges work except for the temp. I did relace the temp switch(for the idiot light) with a sending unit(for the gauge) like I should have, but the gauge shoots all the way up when the car is running. Any ideas as to what is causing the problem?
Old Jan 23, 2005 | 11:03 PM
Nitsuj86Iroc's Avatar
Car: 86 Camaro Iroc-Z
Engine: 305ci TPI
Id say replace the sending unit on the driver side head unless you already did, or if its going all the way up im pretty sure that means its a short. Possibly an open cuircit and if so someone will correct me, but im pretrty sure its a short
Old Feb 3, 2005 | 05:09 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
It's shorting somewhere. It should pin when you are cranking then settle down to whatever it's supposed to read.
Ghettobird52
Jul 5, 2024 11:18 PM
Bstrang6
Sep 8, 2015 04:29 PM
Jote4805
Aug 25, 2015 06:11 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
bamaboy0323
Aug 15, 2015 07:20 AM
