wipers stay on after you turn them off??? turn car off they stop
Car: 86 T/A, 86 z28, 79 berlinetta, 69 chevelle (totally rusted)
Engine: 350's in the f-bodys. 327 in the works for the T/A, MIGHT go with a 383, none in the chevelle
Transmission: T/A has a 5-speed, z28 has a 700-r4, th-350 in the 79' (5 or 6-speed soon), and none in the chevelle
basically the wipers work and all the speeds work, but when you shut them off they keep going, until you shut the car off, wait a second, then turn the car back on, and they go back down. The switch is busted kinda so it keeps twistin sorta if you twist hard (cracked all the way around) but it still goes to the off position, and they don't stay on once you turn it back on, so it's possible, but I don't think it's the switch. oh yeah, it's an 85 iroc.
Just got it. heheh i love it
Car: 2000 Trans Am WS6 (Black)
good ***, I had this HORRIBLE problem on my 1984 Buick Park Avenue... I could get them to shut off sometimes if I turned the wipers off at the EXACT right moment... and if I turned the car off, they would shut off just fine... weird huh?
I finally took it in to an electrical shop once they stopped turning on... but if you ask me its a relay... in fact I know its a relay, I just don't know where or which one...
either a relay or some sort of stop-switch, and maybe the car doesn't know when the wiper hits the end of its cycle?
Good luck
Good luck
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
Probably the park switch or whatever its called. Had it happen to me years ago. replaced it and works since.
any idea where it's at
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
the park switch is inside the wiper motor housing, you have to take the black cover off the motor and its in there, just be careful because if you get the hear out of time your wipers wont work right and might try and park in the wrong place.
Ghettobird52
Jul 5, 2024 11:18 PM
db057
Aug 11, 2015 10:11 PM
