oil pressure and water temp guages
Old Feb 8, 2005 | 07:24 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Engine: 350 sbc goodwrench
Transmission: T-5 in the works
Axle/Gears: 10 bolt 3.42 open
MY oil and water guages arent reading correctly.
Went from 305 to 350 engine .
Do I need to get new water and oil senders for them
to work right?
Any one know what is normal oil pressure for a stock 350
250 HP ?
Old Feb 8, 2005 | 07:38 AM
Soulrev's Avatar
Car: Formerly - 87 T/A, 87 Bird.
Yes.
Not off hand.
Old Feb 8, 2005 | 07:45 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
ok thanks
can u tell me why i need it?
Old Feb 8, 2005 | 12:57 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
My new 350 runs 65+/- when cold, 50+/- when warm. GM standard pump.
Old Feb 8, 2005 | 01:32 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
I guess ill need new oil and water temp sensors.
Is there any other way I could check
my coolant temperature for the time being ?.
I might be runnin hot not sure.
Old Feb 8, 2005 | 05:03 PM
Car: 85 Trans Am
I have a mechanical gauge in the thermostat housing reads about 30* from the sender one, its in the head though...
Old Feb 9, 2005 | 01:03 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
So you hooked up a temperture guage from the thermostat.
I guess its the same kind of setup for a mechanical oil pres guage.
You have to run a hose from your guage to the thermostat?
Into the dash hmmm what if it breaks you could get burned
and crash.
My whole cluster doesnt work the fuse keeps blowin.
Looks like im gonna have to gut the wiring and go aftermarket.
Im a beginner so I might have to go mechanical with the gauges.
I see you also put a bowtie overdrive .
I am interested in this also because my tranny
isnt hooked up to the cpu anymore
and I need an aftermarket kit was it hard to put on?
Old Feb 9, 2005 | 11:11 AM
Car: 85 Trans Am
My temp gauge has the wire type lead, not fluids in my car.
You could get an electtric sender version, this would just require routing the wire through a grommet.
The electronic units are rather simple to setup. Autometer has decent instructions in all the gauges.
I live about 5 miles from BowTie so it was a pretty easy choice. So far the tranny is working good, pressure are near perfect, no slipping and a really nice crisp shift. Withouth the ECU you can use the Brake Relay system, which would cause the TC to unlock when the brakes are on. Their site gives it in good detail.
Old Feb 9, 2005 | 01:08 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
I guess you have to remove your
existing sensors.
The sensors they provide will fit where
the originals where?
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
