sometimes it starts, sometimes it dont
Car: 92 Rally
Hey guys, I have a electriacl problem that I have never seen before. Maybe someone else has expirenced this. 1 out of 5 times when I go to start the car nothing happens. lights work fine but it doesn't make a sound. There is a ticking sound coming from under the dash whenever I turn it off. The trick is that I found a way to override the problem and maybe this will help to lead to the root of the issue. Whenever the car won't start I simply remove the negative battery cable and then reconnect it and it starts everytime. It has a new starter and new battery.
Car: 87 Buick Grand National
Engine: 3.8 SFI Intercooled Turbo
Transmission: 200R4 3000 Stall
take some electrical contact cleaner- clean the chip surface on the key and clean the probes in the ignition cylinder- that fixed my problems with vats. do a search on vats and youll see why.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If what AJT86 has suggested doesn't help, take a good look at the condition of the contacts on the key and the contacts in the lock cylinder. You may have to replace the key or both the key & lock cykinder.
Car: 1987 Camaro IROC-Z
Engine: LB9
heres something that works with the luminas with VATS, not sure if its the same for the f bodys.
Link removed by moderator, if you would like to send that link to him in a PM you may. Material in that link is not something that the admin wishes to have on the board.
92camaroJoe
Aug 13, 2015 06:07 AM
