Speedo goes haywire; service light on
Old Feb 9, 2005 | 05:13 PM
GreenHornet's Avatar
Hello Lads:
My speedometer is not working. most of the time it doesn't register and some of the time it makes feeble attempts to register. the service light started going on at about the same time and it comes on intermittently.
any ideas?
thanks
92 Vert Bird, Formula.
Old Feb 10, 2005 | 07:39 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Check the wires at the VSS sender at the transmission first. Make sure the connector is not corroded. If not, then either the gear for the VSS cracked or the sender is bad. Without the VSS signal the speedo will not work and the SES light will come on because the VSS signal controls trans lock and EGR.
Vintageracer
Jan 10, 2020 05:33 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
podiatra
Aug 31, 2015 09:53 AM
apie2546
Aug 10, 2015 05:43 PM
Omega
Aug 10, 2015 12:46 PM
