HELP me eliminate oil pressure switch
Old Feb 11, 2005 | 06:15 PM
WhiteBird89's Avatar
Car: 04SRT,89Formula,84Z28
Engine: 5.7TPI
I am installing new gauges, one of them being an oil pressure gauge. I also have long tube headers and the switch is too close for comfort. The old school switches are two wires and all you need to do is jump the wire. I have an 89 formula and the oil pressure switch is 3 wires. I don't have the shop manuals and dont know how to bypass this switch.
Old Mar 12, 2007 | 01:55 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
having same prob,switch is too close to my headers.have you fiogured anything out yet?
Old Mar 12, 2007 | 01:58 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The oil pressure switch is a backup for the fuel pump relay. It doesn't need to be bypassed, it can just be eliminated.
If it's too close to your headers, you could relocate it to the top of the block.
Old Mar 12, 2007 | 04:48 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
on the LG4 vehicles what purpose does this switch provide ?(two spade terminals ones)
i know that some dont have an oil sender unit by the distributor.,
Old Mar 13, 2007 | 04:15 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
thanks for replying ,i'll check into the back of the block today.
Old Mar 13, 2007 | 11:11 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Some LG4s had electric "helper" fuel pumps, and on those cars the oil pressure switch turned on the pump. AFAIK, all the LG4s had their oil pressure sender or warning light switch on the top of the block.
Old Mar 17, 2007 | 03:47 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i don't see any holes /or plugs by the dist. however there is a square thing sticking up that a 5/16 wrench fits ?
Old Mar 17, 2007 | 10:59 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's the head of a pipe plug in the oil galley. If it wasn't there you'd have a fountain of oil from the unusued hole.
Old Mar 17, 2007 | 01:52 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
thanks i'll see about getting it out
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
TA8487
Aug 16, 2015 12:21 PM
