Trickster..pleas!!blower Motor Has No High Speed?
Old Feb 12, 2005 | 04:19 PM
irocdaddy's Avatar
Car: 89 iroc,2012 eco 150,roadglide
Engine: zz4
Transmission: t56
O.K. 89 IROC. WHEN I TURN ON THE SWITCH IN THE DASH TO RUN THE BLOWER MOTOR, I GET THREE SPEEDS NOT 4. NO HIGH SPEED. I HAVE PUT 6 SWITCHES IN, ALL ACT THE SAME.
COULD THE BLOWER MOTOR ITSELF BE BAD? IS THERE A RELAY MAYBE MESSING THIS UP?
Old Feb 12, 2005 | 07:39 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i thought there was only, Lo, med, and high speeds. assuming of course you count "off" as well of course that would be 4 speeds.
Old Feb 12, 2005 | 09:11 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Okay, there are 4 settings for the switch. "LO", "M1", "M2", & "HIGH". If you are not gettin anything from the high speed setting, there is a high speed blower relay mounted in the right hand side of the engine compartment near the blower motor. Check that.
Old Feb 14, 2005 | 12:07 PM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
TRICKSTER YOU THE MAN!
WHILE I WAS WAITING FOR A REPLY, READ ONE OF YOUR POSTS THAT INDICATED THERE WAS A FUSABLE LINK ASSOCIATED WITH THE BLOWER MOTOR AS WELL AS THE UNDERHOOD LIGHT. WELL, BOTH WEREN'T WORKING SOOOO, REPLACED THE LINK AND ALL SPEEDS ARE THERE NOW.
Old May 31, 2010 | 09:02 PM
ricci66's Avatar
Re: Trickster..pleas!!blower Motor Has No High Speed?
i know its been a long time ....but where is that fuseable link located ...the one that feeds the hood lite and blower motor high
Old May 31, 2010 | 11:15 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes it has been a long time. That fusible link that you are looking for is one of the small wires that are attached to the hot post of your starter. There is also a small in-line 3 amp fuse for the under hood light located near the right hood hinge. Hope this helps. By the way, to find out which one of those fusible links is bad. Lightly pull on them, the one that stretches is the one that is bad. Enjoy!!!!!!!!!!!!!!
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
BBSDesigns
Aug 11, 2015 07:39 PM
