speedo reading MPH when in park???
Old Feb 13, 2005 | 05:23 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
speedo reading 60MPH when in park???!!!
88 iroc
carbed, ls1 dash, 97 camaro cluster
86 bird vss with the right gears
speedo reads perfect when in gear.
in park, or neutral, it reads 60mph when cold, then about 40mph when the car is warm.
any suggestions ?
thanks.
TJ
Old Feb 22, 2005 | 10:25 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
anyone? just the lil things that make you crazy.
i have no idea.
Old Feb 26, 2005 | 12:07 AM
Vader's Avatar
If I am correct, there is a VSS buffer module or circuitry on the ThirdGen I/Ps. The '97 dash may have a higher impedance input and be detecting slight signal variations from the buffer circuitry that would normally be ignored by the older instruments. Short of watching the VSS output and speedo input with a scope while sitting idle, I don't have any suggestions. If you detect a bit of variation, you might try installing a medium resistance ¼W resistor across the speedo VSS input, about 2.7 or 3.9K as a start.
Jorlain
Aug 24, 2022 05:11 PM
Regal105
Aug 23, 2015 03:45 PM
Irocohio
Aug 12, 2015 08:03 AM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
