need help wiring up a motor swap
Old Feb 16, 2005 | 04:08 PM
RacerDonnie13's Avatar
Car: 1988 Camaro SC
Engine: 383 Stroker
Transmission: TH-350
Im putting a carburated 383 in my 88 camaro. I need to know what wires I need to make this motor run. I am using a MSD distributer, MSD 6-AL ignition box, Blaster 2 coil and will be using an alternator. Ive heard that I have to rewire the fuel pump relay to make that work. Where is that located and how do I rewire it?
Im going to do away with the ECM so I think the only wires i need are the alt. wires and the starter wires but i have no clue which ones they are on that very large wiring harness. Any help would be greatly appreciated.
Old Feb 23, 2005 | 04:28 PM
sleeper415's Avatar
Car: 1990 IROC-Z
Engine: carbureted 383
I am just finishing up my carb swap and I highly recommend you get the shop service manual for your car, it tells you where every wire goes and what it does. I think they might still be having a sale at helminc.com but they might not have your year in stock. I got mine for $36.
Old Feb 23, 2005 | 06:00 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
the helms are much more complete and accurate, hence the higher cost.
In my 91 (don't know if its any diff for yours) i had to do nothing, as long as the stock ecm stayed hooked up. When i went to remove the ecm, to make room for my msd box, i then had to do some wire jumping.
Anyways, to the point; the electric pump is turned on and off two ways... both are controled by the ecm. If you do nothing, but hook back up all the sensors, including the Oil pressure senders, the pump will run as long as there is OP... this is the back up finction in the ecm for running the pump. Mine has run fine this way, and when i pulled the ecm, i merely just had to go about jumping a wire in the ecm harness to another one in the same harness.
Old Feb 23, 2005 | 08:45 PM
juansupreme's Avatar
Car: 86 Trans Am
Engine: 350 Roch-4bbl
Axle/Gears: Normal
I just got a reman 305 4BBL put in my 86 TA.
Car drives great but they had to remove all smog and emmision stuff. computer is not working and can't get any codes to display.
Just purchased a Roch-Qjet form Autozone works great does not need to be pluged in to any connections.
How can I get my car back to specs?
midge54
Sep 2, 2020 07:13 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
st.evel07
Aug 13, 2015 06:15 PM
92projectcamaro
Aug 6, 2015 01:20 PM
