Front Defost switch
Old Feb 21, 2005 | 09:50 AM
DustyJL's Avatar
Car: 91 Camaro RS
Engine: 3.1L V6
Axle/Gears: Stock 3.23 open diff
Front Defost switch
I want to take out my air conditioner controls. I then want to install rocker switches to turn on the defrost and heater. How would I wire this? Has anybody else ever done it?
Old Feb 22, 2005 | 09:23 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Very difficult since the defrost/heater selector switch runs off of vacuum, not electricity.
Old Feb 26, 2005 | 12:22 AM
Vader's Avatar
You could use a spare EGR or EVAP vacuum solenoid valve controlled by a rocker switch. With the solenoidf on, it could switch vacuum to the HEAT door actuator, and with it off, it would dump the vacuum so that the dampers would divert to DEFROST. You would need a multi-position switch to control the blower, however. If you only want to switch the air outlet positions, one switch will do it.
1992 Trans Am
May 10, 2023 07:19 PM
Street Lethal
Apr 30, 2019 12:14 PM
MORREALE5
Sep 13, 2015 09:16 PM
Dialed_In
Aug 20, 2015 01:45 PM
mustangman65_79
Aug 12, 2015 06:39 AM
