Hurst shifter installed what about wires?
Old Feb 22, 2005 | 01:43 AM
KnightWarrior's Avatar
Car: 1985 Camaro Z-28
Engine: 305 V-8 4BBL (H) Supercharged
Axle/Gears: 3.42 Eaton Posi
I put a console dual-gate shifter in my Z-28. I rigged the back up wires to seperate switch, as well as the neutral safety switch, what I'm wondering is what the other two wire that are left go to? Overdrive? Torque convertor lock-up? When should that be switched on? Any forward gears or only O/D?
Old Feb 22, 2005 | 01:52 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Why did you have to rig anything up at all? The factory park/neutral/reverse switch bolts right up to the dual gate.
Old Feb 22, 2005 | 11:55 AM
Because fourteen years prior to this I had a B&M Megashifter that recently broke off in my hand and it had no such provisions for the stock switch.
Old Feb 22, 2005 | 07:39 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Ok, that makes sense.
The heavy purple and yellow wires are for the starter and hatch release safety switch. The black/white and orange/black wires are for the ECM P/N switch. The light green and dark blue wires are for the reverse lights.
rocn7roc
Sep 21, 2021 02:16 PM
camaro11j
Sep 19, 2018 08:49 AM
Caspar
Jun 19, 2016 11:19 PM
NBrehm
Aug 25, 2015 11:49 PM
mustangman65_79
Aug 13, 2015 07:36 AM
