LB9-Carb Keep VSS?
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
LB9-Carb Keep VSS?
Is there any way i can keep my speedometer working if i swapp to carb. What about the rest of my gauges exc. the tach?
Dont know what forum to put this in.
Sorry mod!
Sorry mod!
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If you are planning to keep the ECM then you can still run the VSS. If you don't keep the ECM, then there is a system made by company called the dakota box I believe. The tach doesn't work off the ECM but off the distributor & ignition coil.
Elephantismo
Feb 13, 2019 12:51 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
