bulb help please
Old Mar 8, 2005 | 10:51 AM
Dora's Avatar
Car: 1986 iroc
Transmission: auto
bulb help please
Hi
both turn signal bulbs are out. How do you change them? Remove the gages plate and then the glass? Are all the bulbs under there the same? Doyou need special tools?
Thanks, Dora
Old Mar 8, 2005 | 02:22 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
You can access most of the gauge instrumentation bulbs by just removing the black bezel, plastic lens, reflector. The fuel, tach, volt and temperature gauges can then be carefully pulled out of the white carrier to gain access to the bulbs.
Unfortunately, the turn signal indicator bulbs are down inside a long tube and you'll have to remove the gauge cluster from the dash to get to them.
While you have the cluster out of the dash, you should replace all the other light bulbs. That way you won't have to remove the cluster again for a while.
Old Mar 8, 2005 | 03:08 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check the following link for some info/pics that may prove useful:
https://www.thirdgen.org/techbb2/sho...hreadid=249244
JamesC
Fronzizzle
Feb 9, 2017 09:31 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
podiatra
Aug 31, 2015 09:53 AM
