Testing IAC...
Old Mar 15, 2005 | 11:00 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Testing IAC...
Can it be done? I've narrowed my cold start problem to a stuck-open IAC valve... I've replaced the valve with no change. Either when the terminals came out of the connector, I didn't put them back in the right holes, or there is another wiring problem I can't find... I'm going to go out and buy a new wiring harness connector soon and also need pinouts and troubleshooting diagrams if at all possible. Trickster, your help would be appreciated greatly here .
Old Mar 15, 2005 | 09:50 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Maverick H1L,
Haven't heard from you in awhile, how's life treating you other than this problem with the IAC? Would these little pictures help you any? I know it says 2.8L but the function is the same. BTW, they sell NOID lights for the IAC at most auto parts store for about $7 to $8.00 maybe less in some.
Old Mar 15, 2005 | 09:51 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
And page 2
Old Mar 16, 2005 | 10:09 AM
Engine: 2.7L V6
Axle/Gears: 4.41
Thanks a bunch, but I found the problem myself before you got back to me. I put in my "old" ECM (the one with a permanent code 54 and don't run without a good OPS) , and the thing works... Guess I have to hunt for another ECM...
Old Mar 18, 2005 | 11:22 AM
Engine: 2.7L V6
Axle/Gears: 4.41
BTW, how would you rate A1 Cardone remanufactured ECMs? I have heard some people have a lot of problems with them, including that they corrupt the PROM in some cases . I only need one long enough so that I can afford a GM remanufactured one, and I am not worried about a corrupt PROM since I have a spare that came with the ECM I am using now (the one with no IAC driver module)...
Linson
Oct 24, 2025 02:00 PM
RedLeader289
May 28, 2019 01:47 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Eric-86sc
Sep 28, 2015 11:37 AM
