dash gauge blubs
Old Mar 23, 2005 | 02:00 AM
kolkane's Avatar
Car: 91 Z28
dash gauge blubs
Hi just wondering how many have changed there dash bulbs out and if this is a hard job to do, currently only the tach lights up so i can't see how fast im going at night so they need to be changed. any tips on how to do this would be great, thx.
Old Mar 23, 2005 | 02:08 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Not sure about camaros, but Firebird dashes are easy, take off trim plate, unscrew cluster from dash, pull forward, bulbs are out back.
I recall something about some Camaros have some bulbs soldered to the cluster... don't quote me on that though.
Old Mar 23, 2005 | 06:50 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
No solder. Same proceedure for camaros.
Old Mar 23, 2005 | 07:02 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check the following link for some ideas:
https://www.thirdgen.org/techbb2/sho...hreadid=249244
JamesC
Old Mar 24, 2005 | 07:34 PM
kolkane's Avatar
Car: 91 Z28
ok i figured how to take it apart but now i have a problem, how do i get the headlight **** off? and can i do it without removing the dash, also because im not sure what what exact bulbs to get i know its 161 and 194 but not sure how many of each, can i drive with the speedo cable unhooked?
Old Mar 25, 2005 | 06:00 AM
JamesC's Avatar
I believe the cluster must be removed to yank the headlight ****. If I remember correctly, you should be able to see a small 'lever.' Pull the **** and push the lever. The bulbs are all numbered--simply pull them and verify the number.
JamesC
Old Mar 25, 2005 | 08:42 PM
kolkane's Avatar
Car: 91 Z28
I finally got it all taken apart, the button for the headlight **** on 91 z28's is on the bottom of the switch itself and is easily reached by removing the lower panels by where your knees are the rest is pretty simple, i removed the dash so i didnt have to drop the steering wheel down and the cluster came right out, bad news is the bulbs are all GM replacements.
Old Mar 30, 2005 | 12:02 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
that's a negative... you can get those replacements from an auto parts store. you can also replace them with different color bulbs, if you want. i did mine (more than 4 years ago) on my '91, so i know they're not a GM thing. with that said, no, i don't have the part numbers handy, BUT even though they are an "integrated" type socket/bulb, you can buy them separate and change them out any time you want. i do know for a fact that the sockets can be purchased at auto zone, cuz that's where i got mine. then i put red bulbs in them...
KAM
Old Mar 31, 2005 | 09:53 AM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
I don' t know a source, but pre-made LED bulb/holders are being made for the 194(?) lights for the dash. I heard they weren't expensive.
I'd get those over standard bulbs any day of the week if I intended to keep the car.
Old Apr 7, 2005 | 01:07 AM
csi1286's Avatar
Car: 91 Camaro RS white w/ T-tops
Engine: original 305TBI 140,000mi
Transmission: automatic (although standard would be preffered)
Kolkane,
I have yet to get that **** off... Would you mind expounding on how you did it. particularly what this button is... and/or whether the **** and rod come off together or whether the **** comes off of the rod that it is connected too... mine is 91 RS so i expect its exactly the same. I sure would like to have some gauges at night without the ugly map light hanging out of my cig lighter. Grats in advance.
-steve
Old Apr 7, 2005 | 01:47 PM
Car: '91 Z28
Axle/Gears: 323's
if you play with it enough, as in wiggling it, it will probably come out. mine did that way. the **** and shaft will come out together.
Old Apr 7, 2005 | 04:20 PM
csi1286's Avatar
yeah so I got the thing out **** and rod it really was as easy as pushing that button on the bottom of the switch itself all along i was trying to separate the **** and rod... so heres my new issue it wont click back in so i dont have headlights is there some trick to getting it back in or is it just supposed to click in?
thanks
-steve
Old Apr 7, 2005 | 04:27 PM
csi1286's Avatar
whew nothing is broken it went back in just had to fiddle with the button and give a little gentle persuasion from the business end. Thanks guys now i can finally have dash lights.
-steve
Old Jul 1, 2005 | 10:24 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I think I broke mine. I can't get it to go back in. the button is not locking the shaft back in, so how can I replace the whole switch?
Bubbajones_ya
Jul 6, 2024 08:32 PM
MantyZ28
Nov 8, 2015 06:54 PM
TrevinE
Sep 14, 2015 03:20 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
86IROC112
Sep 11, 2015 04:04 PM
