Battery drops when A/C is on.
Old Apr 6, 2005 | 06:38 AM
corninest's Avatar
Car: 1988 Camaro RS
The battery gauge will constantly drop when the A/C is on at low speeds. Not just go down when turned on and then goes back up, but continues its descent unless you turn off the A/C. Well over stock amp alt and 900 cca battery are new. wires were also changed from alt to battery to go with the bigger alt. While this is going on the car also over heats. But that is in the 'cooling' board.
Old Apr 6, 2005 | 08:28 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Mine did that too. The AC draws a fair amount of power, it needs the engine to rev up and cause the alternator to crank out more juice.
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
colton_carlson
Mar 8, 2019 12:21 PM
stalkier
Aug 13, 2015 12:59 PM
