Where do these connectors go?
Old Apr 6, 2005 | 11:08 PM
stiers's Avatar
I have a few connectors loose on my GTA('87 5.7 TPI). One of them has 2 connections and is on the same wire loom as the round AC compressor connector and some sensor on the drivers side engine block near the first 2 plus. I cant find anything to plug it in to.
Other one is a wire splice off a relay or module in front of the air cleaner/ charcol canister. It is a green w/ white stripe wire. Any idea what this wire is for?
I also have a blue wire with a ring connector on the end that goes into the main wiring harness that runs down the fender on the passenger side.
Old Apr 7, 2005 | 07:10 AM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Do you have any pictures of them?
Old Apr 7, 2005 | 09:18 AM
stiers's Avatar
If I had a digital camera the pics would be in the post and I could have saved myself some writing. Unfortunatly. I dont have one.
Old Apr 7, 2005 | 10:56 AM
Benm109's Avatar
Engine: 305 TBI
After some thinking, I might know what 1 of them is.
Those sound like the connectors for the AIR control valve solenoids. It sounds like the previous owner deleted the AIR system from the car (not uncommon). Are there small metal tubes running into and on top of the exhaust manifolds? Is there an AIR/smog pump directly under the AC compressor? Is there a large (about 4" by 4") plastic box right next to or behind the compressor with large hoses?
Old Apr 7, 2005 | 11:54 AM
stiers's Avatar
All the emissions stuff is still on the car and it is bone stock.
Old Apr 7, 2005 | 12:09 PM
Benm109's Avatar
Engine: 305 TBI
OK. Well, near the AC compressor there should be a large black box, which should look like this:
Those 2 loose connectors should plug into those 2 solenoids on it, the black and the gray devices.
Old Apr 7, 2005 | 02:52 PM
stiers's Avatar
Thats on the passenger side of the car and the wires are plugged in. The '87 TPI uses a 3 belt system and diffrent brackets than the serpentine setup on the '88+ cars.
Old Apr 7, 2005 | 06:48 PM
stiers's Avatar
Pictures finally.
Old Apr 7, 2005 | 11:55 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
I could be wrong, but from first glance it looks like the AC clutch connection that would go in between the clutch and compresser housing. Mine is at the 2 o'clock position when facing the clutch side of the unit.
If you just spun the camrea from where it was at to just behind the clutch it should be there.
Old Apr 7, 2005 | 11:59 PM
stiers's Avatar
I didn't see any extra connectors on the AC compressor anywhere... is it covered by a support beam or housing somewhere? There is one connector already plugged into the compressor.
Old Apr 8, 2005 | 01:35 AM
Scorpner's Avatar
Engine: V6, V8
It's kind of late but I'll go out and look.
It's actually on the clutch, not the compressor.
There's two flat prongs that fit into the connector. Mine is actually at the 3 o'clock position. Look at the plug and then in behind the clutch. i think it goes there also because of the shape of the wiring to the connector. It as to curve like that so it doesn't interfere with the clutch and belt etc.
Old Apr 9, 2005 | 09:19 AM
BruceEmbry's Avatar
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
That is the AC Clutch connector. I have the exact same connector on my 82 Firebird.
Old Apr 9, 2005 | 02:34 PM
stiers's Avatar
So it plugs in somewhere on that blue monster?
Old Apr 9, 2005 | 04:35 PM
stiers's Avatar
I figured out where it goes. Now the problem is that the connector is too short, it had electrical tape wrapped around it so I peeled it off and there is a little resistor connecting the black and green wire. Is this normail or have I found another red neck hack from the dip**** previous owner?
Old Apr 9, 2005 | 06:45 PM
BruceEmbry's Avatar
Thats not a resistor, its a diode. The diode will cause the field of the AC clutch to collaspe faster so the the AC compresser will stop faster.
Old Apr 9, 2005 | 10:21 PM
Scorpner's Avatar
Engine: V6, V8
I was wondering about that. Mine runs from underneath and around the outside. Somehow you need to route it differently.
Try following the wiring back to the main harness and see if you can untangle it and bring it around the other way. I can check tomorrow if you need and maybe take a pic if necassary.
Old Apr 10, 2005 | 12:30 AM
stiers's Avatar
Which wire is on top, green or black?
Old Apr 10, 2005 | 01:17 AM
Scorpner's Avatar
Engine: V6, V8
I can't tell. mine is a 2.8 so i'm not sure if they're the same anyways. When i looked, the open part of the plug is facing toward the front of the car. Also the connector runs pretty much straight from the harness to the connectors on the side farthest from the engine.
I looked at the curve of the wiring from the connector to reconstruct how it plugged in.
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
