found all my answers but 1
Old Apr 11, 2005 | 02:44 AM
WhiteGhost's Avatar
Car: 00 Trans Am
Hey guys.. I now know what each wire on my alternator does, where it goes, and what it should read on a voltmeter.. (researched it through the "search" button ) I can run a patch from the back of the alt straight to the + battery terminal to test that wire.. then if that doesnt work i can patch the brown wire to a 12v switched sourse (fuse block).. if that doesnt work I am still unsure of where I can patch the red wire on the top plug.. I know its a constant 12v.. can I just patch it straight to the battery to test it?? I want to figure out which wire is keeping the alt from charging the battery... so I know how to test two wires.. just gotta figure out the last one.. (red wire on top, 2wire plug)
Old Apr 11, 2005 | 03:39 PM
WhiteGhost's Avatar
Car: 00 Trans Am
problem fixed.. the "sense" wire wasnt receiving anything.. so the alt didnt know to charge when the key was on.. i simply ran a patch from the preexsisting wire I had run for the fan.. now anytime the switch is turned on the alt knows about it.. and in turn.. it charges..
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
angel2794
Sep 8, 2015 06:22 PM
IROCZ1989
Sep 4, 2015 11:54 AM
tgp1990
Sep 4, 2015 06:24 AM
rudolphschenker
Sep 4, 2015 02:41 AM
