donor options for mpfi harness for 730 ecm
Old Apr 13, 2005 | 07:08 AM
cmexlr8's Avatar
Car: 1965 Chevelle SS
Engine: 355
Transmission: TH350
Besides the 90-92 v8 tpi harnesses, what other harnesses will make good donors? I think I read that the 3.1L harnesses will work with out much repinning but obviously two more injector wiring sets need to be added. I am looking for an option that will allow me to use a 730 sd setup on my as&m BBC TPI without alot of repinning. If I have to use a v6 setup, I do not mind adding on the two injector wire sets.
Old Apr 13, 2005 | 07:03 PM
cmexlr8's Avatar
Engine: 355
Transmission: TH350
is this question in the correct forum?
Old Apr 15, 2005 | 02:09 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
There is a thread in the TPI boards right now on repinning a TBI harness. V6 harness can be used, you just have to add to it. Any year TPI will do. You just need to spend your time with elctrical diagrams.
64goatman
Sep 9, 2015 01:09 PM
L0tuS
Sep 4, 2015 11:16 PM
Billy Decker
Sep 4, 2015 03:46 PM
IROCZ1989
Sep 4, 2015 11:54 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
