how to bypass vats systeme
Old Apr 23, 2005 | 09:41 PM
irocbadboy's Avatar
Car: camaro and gmc sierra
Engine: 5.0 l t.p.i,and 4.3 vortec
Transmission: manuel(iroc)automatic(other)
Axle/Gears: 3.45 bw
Hi guys,i'm putting a 5.0l tuned port injection 1990 with the vats systeme in the 1993 chevrolet pick-up 1500 but the truck does not have the vats system,the engine start when i put the gas in the intake but the injectors do not have a pulse,and i don't have the vats systeme,how to make for the bypass?please help!!!thanks
Old Apr 23, 2005 | 10:00 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Are you just putting engine in the truck or the computer as well? If you're not putting the computer in it there is nothing to worry about. If you are putting the computer in it then just take the VATS control module, starter enable relay, and the lock cylinder and put it in also.
Old Apr 24, 2005 | 09:21 PM
irocbadboy's Avatar
Axle/Gears: 3.45 bw
Old Apr 24, 2005 | 09:27 PM
irocbadboy's Avatar
Axle/Gears: 3.45 bw
yes trickster,i'm putting the engine and the computer(1990)but I want nothing to know &?%%?$#$vats systeme,how to bypass this systeme to make it function?one chip with vats canceled,i don't now
Old Apr 25, 2005 | 11:10 AM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
Options for VATS is to swap everything into the new vehicle, or disable VATS somehow, easiest way is through an edited PROM.
Old May 3, 2005 | 03:11 AM
Javelin3o4's Avatar
Car: 1971 Camaro
Transmission: TH350
you have to measure the ohm rating on the original key that was used on the car that had the VATS system, then you have to get a resistor to match that value of i believe with a difference of no more than +/- 5% then "normally" when you bypass the vats system there will be a 2 really thin gauge wires with orange tubing around it running up to the column. there is a plug which you can pull apart and from there put the resistor on the side away from the ignition crossing across the 2 wires, this should bypass the vats system in thinking the correct key value is entered into the ignition.
Old May 5, 2005 | 06:31 PM
theno1prince's Avatar
Car: 1987 Chevy V10
Engine: 5.7L
Axle/Gears: 4.10
What do you do if the guy you bought the car from lost the original key? Any cheap or free solutions?
Old May 5, 2005 | 06:34 PM
stenseltizm's Avatar
Car: 89 RS
Engine: 400 sb
From reading on this board, I believe most people say that gm only used 15 different key resistors. do a search on here for that thread and it will tell you which 15. then buy those resistors and trial and error until you find the one that works. permanently add it to your wires, then get a non resistor key.
*edit-i did the search for you, and found that the resistances were removed. something about it not being the boards policy to publish them. go to a shop that installs car alarms, and they should be able to tell you which resistors you need to try. sorry
Old May 5, 2005 | 09:54 PM
Javelin3o4's Avatar
Car: 1971 Camaro
Transmission: TH350
hope i dont get in trouble posting this link
http://www.velocitymotorsport.com/im...notes/237a.jpg
junior419
Apr 7, 2025 11:35 AM
sahlomonic
Sep 20, 2015 07:15 PM
Racerx974
Sep 19, 2015 10:16 AM
383cam
Sep 9, 2015 06:01 AM
studebaker60
Sep 7, 2015 12:36 PM
