gauge lights
Old Apr 27, 2005 | 01:00 PM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
gauge lights
can someone tell me which wires are responsible for the gauge lights....my interior lights, headlights, and parking lights all work, just not the gauge lights. the fuses are ok, so that is why i think it's a wire. the bulbs are ok too.
1988 firebird 2.8 mpfi
thanks
Old Apr 27, 2005 | 09:59 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Have you thought about the "Remote Dimmer" being bad? This will cause the guage lights to not work.
Old Apr 28, 2005 | 01:00 PM
eagle_eyes's Avatar
Engine: '93 LT1
u mean the connection from the dimmer to the gauges? the connection from the dimmer to the dome lamp works.
Old Apr 28, 2005 | 03:14 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
No, I mean the transistorized Remote Dimmer that is between the fuse and the light switch. It sort of looks like this.
Old Apr 29, 2005 | 12:54 AM
eagle_eyes's Avatar
Engine: '93 LT1
thanks. i'll check it. while i was down there the other day, i did find a couple of wires that were cut by rubbing on this metal bracket. i don't remember the colors....i THINK one was pink. i put them back together and blocked it form the bracket, but that didnt help.
Old Apr 29, 2005 | 09:28 AM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
Check the fuses again..if you only checked the "light" fuse, id still i'd pull em 1 by one ...if the wire was cut in half by that bracket, odds are they blew a fuse or 2. Also, if it blew a fuse, and multiple things are tied into it, it may explain your lighting problem.
Old May 21, 2005 | 11:02 PM
eagle_eyes's Avatar
Engine: '93 LT1
i checked all the fuses...they're ok. the gauge lights don't work, but the "check engine" light does and the high beam indicator and turn signal indicators work. i've heard of this one part, but i don't know it's name at a part store. i've heard it been called a "remote dimmer module", "switching transistor", "second dimmer switch", "power transistor","transistorized Remote Dimmer", and "dimmer switch" what is it that i probably need? i know that the floor board and dome lights come on when i turn the wheel all the way up...if that helps. thanks
Old May 22, 2005 | 09:57 PM
eagle_eyes's Avatar
Engine: '93 LT1
bump
Old May 24, 2005 | 12:03 PM
eagle_eyes's Avatar
Engine: '93 LT1
anyone???
Old May 24, 2005 | 11:31 PM
SOX 19's Avatar
Car: 88 Formula, 01 Tundra
Engine: 305, 4.7 V8 17mpg
Have you tried replacing the switch? Could have gone bad!
Old May 24, 2005 | 11:44 PM
eagle_eyes's Avatar
Engine: '93 LT1
i went to autozone and got a "gauge cluster dimmer switch" which is what the problem was. thanks for all of your help.
Old May 25, 2005 | 12:03 AM
SOX 19's Avatar
No problem, sorry I was late!
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
firebirdta84
Interior Parts Wanted
Aug 30, 2015 09:28 PM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
