Engine wiring question
Old May 7, 2005 | 12:40 PM
slow83sc's Avatar
Car: 83 camaro sport coupe/ 1981 Camaro
Engine: 2.8 2bbl
Transmission: thm200c
I'm swapping from a 2.8L 2bbl engine to an 85 z28 lg4 engine.
My car is a 1983, can I just unplug the wires at the firewall and plug the v8's in?, or is the wiring on the column and underdash different?
If I can use the wiring does my existing wiring have support for the instrument cluster from the Z?
I'm not using any of the computer controls from the Z, just the engine wiring from the drivers side, I'm going vacuum dist and old quadrajet.
Thanks in advance for any replies, you guys always have an intelligent answer.
Old May 12, 2005 | 12:40 PM
slow83sc's Avatar
Engine: 2.8 2bbl
What I meant was will the bulkhead connector interface with the one fron the 85Z, or will I have to swap out the whole dash harness?
Old May 19, 2005 | 09:28 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
The driver's side bulk head connector of C100 has two purposes:
1. (Right side) Carry all electrical wires for the headlights and horn and such.
2. (Left side) Carry all electrical wires for the engine and sensors.
You should not need to even unplug it. Just get a diagram or follow wires to see where they lead in the engine.
Caspar
Jun 19, 2016 11:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
