code 34
Old May 25, 2005 | 12:24 AM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
code 34
my computer is throwing a code 34 which i was assuming that it's the MAF, so i went to autozone and got another MAF, hooked it up, erased the codes, and tried it out, but the code came back. does anyone have any ideas on what else it is....i'm not good in the computer area.
Old May 25, 2005 | 01:08 AM
92'Sleeper's Avatar
Car: 92' B4C Camaro
Transmission: G-Force T5
Clear your code again.
Disconnect MAF Sensor.
Start engine, let run until Engine light comes on.
Ignition "ON", Engine stopped.
Ground diagnostic terminal and note code.
Code "33", Faulty MAF Sensor.
Code "34", check for short to ground in CKT. 998 (DK Green wire).
If not shorted to ground, faulty ECM.
CKT.998 (C @ Sensor) (B12 @ ECM for PN1227165)
If this CKT. is not acurate for your set-up, just find the 5v signal wire on your MAF.
Old May 25, 2005 | 02:24 AM
DanTheMan_smlk's Avatar
lol, i just HAVE to say this, but when u arent refering to a car, code 34 means "hot chick alert" if you are at work (like supermarket, fast food...)
sorry
Old May 25, 2005 | 12:05 PM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Re: code 34
Most likely you have a bad MAF relay, either burnoff or power. Can't remember in 88 if its on the firewall on at the ECM.
Old May 26, 2005 | 12:42 AM
eagle_eyes's Avatar
Engine: '93 LT1
92'Sleeper
i tried your steps and got a code 34. i didn't have time to check the relay or wires yet, but that's next in line.
Old May 26, 2005 | 01:44 AM
92'Sleeper's Avatar
Car: 92' B4C Camaro
Let us know what you find out.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
