Relocated my battery now i have noise in the speakers???
Old Mar 28, 2004 | 10:02 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
Okay guys i just finished relocating my battery to the passenger side in the spare tire well. Well after everything is together and whatnot i was riding around tonight and im gettin a whining noise in my speakers. i have the ground for the battery on the same spot for the ground as my amps. the stock wire has to wires for ground. onefor the motor and one for the chassie. do i have to connect a wire to the motor from the battery or what? let me know thanks. its not that annyoing but i just wanna get rid of the noise.
Old Mar 29, 2004 | 04:37 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
move the ground cable away from the amp ground, do you have a large gauge cable from the engine to the body?
if it still makes noise, you can get a ground loop isolaler that plugs into your RCA's that should work then
Old Mar 30, 2004 | 05:49 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
yeah my friend told me to run a ground wire from the battery up to the motor. then ill move the negative where it is to another bolt. i just gotta get some battery wire.
Old May 22, 2005 | 07:15 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
Transmission: 700R4, lots of Mods
Did you ever fix the speaker noise, I did the same thing, relocated the battery now I have noise in speakers, when ever I turn on something electriacal, like pressing the brake, head lamps etc..all grounds are good.
Old May 23, 2005 | 11:31 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
yeah after i ran a wire from the negative to the motor to ground it out, no more noise.
Old May 25, 2005 | 12:19 PM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
The longer the wires from the battery the more likely you will pick up noise. It's common in two way radios to get alt whine when the wires are not attached close to the battery. An auto battery is an excellent filter for such problems, but when you lengthen the wires and get further from the low impedence of the battery you will increase the likelyhood of ignition noise as well as alt whine. If it's a problem there are commercially made filter chokes to reduce it, just get one for the maximum current the stereo draws.
Old May 25, 2005 | 05:08 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
that is exactly what I figured would happen, going to buy those filters..do you have a good name brand / part number I could try?
Or where can I get them?
Old May 26, 2005 | 07:42 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Any decent auto stereo place should have them, they all use pretty much the same internals.
gta892000
Aug 11, 2019 11:16 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
customblackbird
Oct 1, 2015 04:30 PM
mcbitchman
Sep 30, 2015 01:00 PM
luvofjah
Sep 10, 2015 10:41 AM
