too large power wire?
Old May 25, 2005 | 11:46 PM
Kandied91z's Avatar
is there such thing as too large of a power wire for your car?
i recently had to add two extra batteries to my car totalling 3 now and they are all in the trunk. i have a 4 guage presently that ran power from my one and only main redtop in the rear. now i have 3 yellow tops and figure it would be a good idea to upgrade. i was told to run a 1 gauge which is pretty expensive but if it's necessary i'm all for it.
what do you guys think?
Old May 26, 2005 | 04:40 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
I'd say run a 4 or 2 for each, typically easier to route the smaller wire, and thinner under the carpet.
Old May 26, 2005 | 07:55 AM
Tranny's Avatar
Car: 87 Trans Am
Engine: 434 being built
Axle/Gears: 3:73
welding cable!
If you check at one of your welding supply stores in your area they will carry #1, 1/0, 2/0 copper stranded cable thats easy to work with & costa lot less! I've been told by them they can order in colors other then black too!
Later, Bill
Old May 26, 2005 | 04:40 PM
Kandied91z's Avatar
really? i'll have to check into that. thanks!
i have 18' of 1 guage that i bought to use for my stereo, it's long enough to make the passage up to the front but was $125 for the lot.
Old May 26, 2005 | 04:42 PM
Kandied91z's Avatar
i need to run just one main up to the front. i currently have 4 but i have a much more extreme draw of power now so i was thinking of throwing the 1 guage on it. i'll use the 1 guage to connect the actual batteries yes but i wasn't sure what guage i should run up front for the engine.
Old May 26, 2005 | 10:24 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i ran one guage wire from the battery in the back to the front. i believe it ran around $50 from a welding supply store.
Old May 27, 2005 | 12:51 AM
Kandied91z's Avatar
good deal, i'll definately check it out then... thanks!
BRoss99
Aug 10, 2025 05:08 PM
Bert87
Aug 23, 2015 03:50 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
stalkier
Aug 13, 2015 12:59 PM
ZsTransAm
Aug 11, 2015 07:30 PM
